60mm with 17"s
MadE30mike
Mon Oct 11, 2010 4:22 pm
my sport is lowered 60mm and iv just got a set of 17" alpina reps.
anyone had experiance with this, good idea bad idea ? does it rub
my last sport was lowered 40 with reps and had no problems just handling was crap compared to standard bbs
Mon Oct 11, 2010 4:28 pm
well this one will handle worse if it's lower :)
Should not have any rubbing problems if using 205/40/17 tyres
Mon Oct 11, 2010 4:32 pm
Back in the bad old days before I had my PC injection I would have told you , don't do it, your car will look truly council and drive like sh1t .
Fast forward to October 2010 and I reckon it will look phat/sick /lush/heavy and you'll be d a man, ain't it ! :)
e30mtec
Mon Oct 11, 2010 5:03 pm
ive got 17s on a 40 ,thought it was a 60 drop long story ha ha.looks ok but dont handle the best..go 16s max or 15s on a 60 drop
e30-EVN
Mon Oct 11, 2010 5:06 pm
mines lowered 60mm on the same wheels as you (gloss black) winkeye , 205/40/17, does not rub when driving but the occasional little rub on full lock, this has only happened like 2 times and is only the arch plastic, i just stay away from 'literal full lock' when turning. she handles brill, front feels nice and sharp and looks the nuts :cool:
Mon Oct 11, 2010 5:12 pm
its the law if your fitting Alpina reps 60mm drop and use a pair of molegrips to roll your arches :)
Clarkyboy
Mon Oct 11, 2010 5:50 pm
i had 205/40/17's on my is, lowered more than 60, et 35 offset, there was no rub front or rear, you should be fine,
im now on 225/50/15 on the rear (et 25) and 205/50/15 on the front, no scubbing either, delighted, it looks so low and fat!
i rolled my arches before the respray too, but i ran the 17's long before that and it didnt cause me any trouble.
oomz1975
Mon Oct 11, 2010 7:49 pm
No issues here, 205/40/17 tyres all round. Handling is great especially after refreshing all the rubber bushes on the car too.
Ajsingh
Mon Oct 11, 2010 8:07 pm
I have a 60mm drop on alpina rep alloys covered in 215/40 17 dunlop rubber... It has never rubbed on the arch or anywer else.. Might get a slight exhaust scrape if theres a fatty in the car but otherwise never...
E30 Crazy!
e30mtec
Mon Oct 11, 2010 10:57 pm
i get that all the time winkeye
smile for the speed camera ..
e30mtec
Mon Oct 11, 2010 10:59 pm
Alex wrote:its the law if your fitting Alpina reps 60mm drop and use a pair of molegrips to roll your arches :)
does that molegrips tip work? i know im sounding thick but seriously does it? :o:
Ajsingh
Mon Oct 11, 2010 11:02 pm
hahahaa....
e30-EVN
Tue Oct 12, 2010 10:06 am
rolling arches with molegrips??? 8O lmao, not even a slightly good idea. it will crack the paint around the inner edge and then rust mate. like i say im dropped 60mm with no need to break out the molegrips haha
Kemix
Tue Oct 12, 2010 10:56 am
molegrips to roll arches :chuckle:
Clarkyboy
Tue Oct 12, 2010 1:30 pm
i used a panel beating hammer and a block - thats how it used to get done back in the day.... but you MUST must must protect the paint if any gets cracked, chipped etc, paint then pack with sealer/waxoil/schutz etc..
e30-EVN
Tue Oct 12, 2010 2:08 pm
am i right in saying you can get ''white schultz''?? i wanted to have the underside of my car sprayed in it but white to match my car, obviously :)
Clarkyboy
Tue Oct 12, 2010 3:44 pm
aye you can get white, gray or black - im not sure waht other colours are available but those are the three that i have used in the past. also you can get shultz with waxoil added too - its supposed to be the dog's never dries out/hardens etc so you allways have a protective layer
e30-EVN
Tue Oct 12, 2010 3:47 pm
yeah white is what i wanted for mine, how much and where from mate?
Clarkyboy
Tue Oct 12, 2010 3:55 pm
you should be able to get it from your local trade/motor factor or if you have a local body shop they would be able to order it in for you i would imagine
Dezzy
CR24v it's a lifestyle
Tue Oct 12, 2010 3:56 pm
Ha ha ha.
Yeh it's the way all the wide boys roll!
Ajsingh
Tue Oct 12, 2010 10:05 pm
I once heard soome rolled there archers on a e36 by wedging a baseball bat between the wheel and the arch on the front and then slowly drove forward!!
Hahaa what a knobber!!!
