60mm with 17"s
MadE30mike
well this one will handle worse if it's lower
Should not have any rubbing problems if using 205/40/17 tyres
Back in the bad old days before I had my PC injection I would have told you , don't do it, your car will look truly council and drive like sh1t .
Fast forward to October 2010 and I reckon it will look phat/sick /lush/heavy and you'll be d a man, ain't it !
mines lowered 60mm on the same wheels as you (gloss black)
, 205/40/17, does not rub when driving but the occasional little rub on full lock, this has only happened like 2 times and is only the arch plastic, i just stay away from 'literal full lock' when turning. she handles brill, front feels nice and sharp and looks the nuts
i had 205/40/17's on my is, lowered more than 60, et 35 offset, there was no rub front or rear, you should be fine,
im now on 225/50/15 on the rear (et 25) and 205/50/15 on the front, no scubbing either, delighted, it looks so low and fat!
i rolled my arches before the respray too, but i ran the 17's long before that and it didnt cause me any trouble.
Ajsingh
I have a 60mm drop on alpina rep alloys covered in 215/40 17 dunlop rubber... It has never rubbed on the arch or anywer else.. Might get a slight exhaust scrape if theres a fatty in the car but otherwise never...
E30 Crazy!
does that molegrips tip work? i know im sounding thick but seriously does it?Alex wrote:its the law if your fitting Alpina reps 60mm drop and use a pair of molegrips to roll your arches
smile for the speed camera ..
rolling arches with molegrips???
lmao, not even a slightly good idea. it will crack the paint around the inner edge and then rust mate. like i say im dropped 60mm with no need to break out the molegrips haha
aye you can get white, gray or black - im not sure waht other colours are available but those are the three that i have used in the past. also you can get shultz with waxoil added too - its supposed to be the dog's never dries out/hardens etc so you allways have a protective layer
e30mtec wrote:does that molegrips tip work? i know im sounding thick but seriously does it?Alex wrote:its the law if your fitting Alpina reps 60mm drop and use a pair of molegrips to roll your arches
Ha ha ha.
Yeh it's the way all the wide boys roll!
