Carpets
- god-father88
I've never seen a e30 with black carpets!..So i can't purchase a used one from a scrappy! any recommendations on what i can do to make them black!? dye?!
- god-father88
cheers imy!
iDreamBeemer
carpet dye?nickso wrote:i need to dye a carpet black soon, any recommendations for what to dye it with?
http://www.valeterspride.co.uk/black-ca ... l-69-p.asp
nickso
- Location: Go do that voodoo that you do so welllllllll!!
er right.....that simple.iDreamBeemer wrote:carpet dye?nickso wrote:i need to dye a carpet black soon, any recommendations for what to dye it with?
ta.
'88 e30 328i M52 track bint.
iDreamBeemer
Sorry, couldn't help myself!nickso wrote:er right.....that simple.iDreamBeemer wrote:carpet dye?nickso wrote:i need to dye a carpet black soon, any recommendations for what to dye it with?
http://www.valeterspride.co.uk/black-ca ... l-69-p.asp![]()
ta.
Planning on doing this myself, you can fill it in the spray bottles (bought a 2 pack from poundland) and a couple of light coats should do it. Can't be arsed to take the whole carpet out so will spray it while still in the car.
Seen a couple that eko has done using this technique and carpet dye and they have always come up really nice.
- Brianmoooore
A twenty year old carpet will be filthy! You're just dyeing dirt.
Really needs to come out and be jet washed first.
yeah i wet vac'ed my interior and the water in the return tank was like grey paint!brought the colours out a treat!Brianmoooore wrote:A twenty year old carpet will be filthy! You're just dyeing dirt.
i would do this first before the dying as brian said!
1989 dolphin grey 325i mtec II
airborne_7
Did my carpet with black carpet dye a while back for my 325 sport, i took the carpet out washed it well using a jet wash let it dry then used a 5 litre tin of black dye from ebay about 20 quid, i used an ordinary spray bottle and did about 2-3 coats and noticed it turning purpleish once dry so i did another coat this time agitating it in with a big paint brush, seemed to work better however... I found that trying to rinse the loose dye off after id let my last coat dry took most the dye off so it was back to square one in a way, so i did the process again then threw it back in the car without rinsing and its stayed a good black colour now for3 months and ive not had problems with my shoes getting stained just make sure each coat gets agitated in in my opinion
