325i sport lowering. what drop on bbs?
hi guys, i searched but i cannon find! im after pics of a sport tech 2 with 80mm drop all around or even just the front 60mm at front aswell with 17" alpina reps. if any ones got any pics would be great because im buying springs and shocks soon and dont no what drop to go for. thank youuuuu
Ant
- Retired Team Member
- Contact:
60/60 bad call for a few reasons.... 80/80 just madness
Sump will be intimate with even the smallest speed bump !
Too low, will scrub inners on full lock , plus extreme neg camber on rear wheels, no good for handling or tyre life.
with 17" wheels with the correct offset the car will be spot on with 35/35 IMHO, you can tweak another 10mm out of the front with thinner spring pads( dealers !)
iirc Wilson325i had the lowest for a while, should be pix here somewhere.
Email FTW
shimsheemer
Get practicing those 18 point turns...
shimsheemer
Check out Rav335uk's for sale thread, got some 16" BBS Splits...unmol wrote:. might just have to get some 16's (bbs splits)
this tells you all you needd to know. Now decide whether you want a car to look at or one to drive.maz1 wrote:was on 17 inch alpina replicas now on 15 inch bbs... I have covered less than 3000miles on the kit and i'm seriously looking to go back to standard or near standard setup. It does however look good with the 60/40 drop!!!
