fitting se side skirts
Messenjah
Thu Mar 04, 2010 11:28 pm
hi guys got some se skirts for my tourer but not got the little breen bits that they clip into ... anyone got a part numer for them or should i just drill holes to push them into and make do without the clips ...
hopefully someone knows what im talking about ?
GC318
Fri Mar 05, 2010 1:44 pm
Don't do it with out the clips, your dealer should still be able to supply these and I think the fitting guide/templates. Make sure you waxoil any holes you drill really well.
Fri Mar 05, 2010 2:12 pm
drill holes :eek:
darkchild
Fri Mar 05, 2010 2:59 pm
magpie wrote:drill holes :eek:
Why not? Its how BMW recommended they be fitted. Done properly it will be fine.
Fri Mar 05, 2010 4:08 pm
sure.
a 325ise with factory skirts
i have some se skirts i'll be fitting soon.i wont be drilling any holes either.
Fri Mar 05, 2010 6:47 pm
I have several E30's with factory fitted side skirts, and not one of them has ANY rust associated with their fixings. Drill the holes and treat the exposed metal with zinc rich paint, as per BMW fitting instructions.
There should be a strip of tape applied along the body as well, where the top edge of the skirt touches the body.
The rust in magpie's pic isn't uncommon on E30's and is caused by rust and water penetration from under the wheel arch area.
snakebrain
Fri Mar 05, 2010 8:50 pm
Messenjah wrote:hi guys got some se skirts for my tourer but not got the little breen bits that they clip into ... anyone got a part numer for them or should i just drill holes to push them into and make do without the clips ...
They're definitely still available for the E28 M-Tech kit, because I ordered some the other day. Might even be the same part. If it is, the number is 51711932996. :)
adit
Fri Mar 05, 2010 9:17 pm
i thought the sills already had holes in them at the bottom anyway, for drainage
[quote="bss325i"]
Fri Mar 05, 2010 10:49 pm
sills,or do you mean the contour of the skirts.
if the sills have holes weld on the skirts :P
M42
Sat Mar 06, 2010 11:54 pm
you can still get the green things from the dealers, i ordered some when i fitted se skirts in my old 318is. you need them so the skirts fit nice and tight on the body. i just measured the distance i needed to drill each hole, but make sure you use masking tape. mine turned out pretty good. i sold the car to another zoner. blue eyes is his name if you want to check it out.
