would 320 touring exhaust fit 318 touring?
jollygreen
Thu Feb 25, 2010 8:08 am
see subject
Thu Feb 25, 2010 8:31 am
no! unless it has a m20 fitted.
johnt0709
Thu Feb 25, 2010 8:37 am
It would be nice to have a table of what exhaust fits what car - seems confusing just now 2 piece, 3 piece, 320 - 325 , cabbie, touring saloon :?
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
Thu Feb 25, 2010 8:56 am
Apart from the fact that twin tail pipes won't fit through a rear valence that has a cut out for a single pipe, cab/saloon/touring exhausts are all interchangable.
Thu Feb 25, 2010 9:00 am
an m20 wont fit an m40 though surely :?
Thu Feb 25, 2010 9:05 am
magpie wrote:an m20 wont fit an m40 though surely :?
That depends how handy you are with a welder.
The point I was making is that the body type is relevant to this discussion. Floor pans are the same.
Thu Feb 25, 2010 9:16 am
i nearly mentioned the welder.
johnt0709
Thu Feb 25, 2010 9:22 am
so M20 exhausts are intechangeable - providing you renew from the manifold back, i.e if you buy a full 2 piece or 3 piece they will fit regardless of b20, b25 cabbie, saloon touring?
Thu Feb 25, 2010 9:28 am
yes.
**BANNED**
Thu Feb 25, 2010 3:14 pm
johnt0709 wrote:so M20 exhausts are intechangeable - providing you renew from the manifold back, i.e if you buy a full 2 piece or 3 piece they will fit regardless of b20, b25 cabbie, saloon touring?
Wish it were that easy...
The manifold/downpipe connection can vary on the M20's.
3 or 4 bolts and a slightly different spacing as well.
The simple solution is a hottuning manifold and a GSF centre and rear!
The expensive option is a BTB3 and BMW supplied centre and rear,or your choice from the various aftermarket stainless systems.
There are two issues with the stock cast manifold.
1.The fitting to the downpipe varies,and seems to be random,possibly a supplier issue at manufacture?
2.The thing tends to go 'banana' shaped over time,this causes head studs to be pulled out,usually the 'difficult' one's at the rear of the head.
Second issue was addressed by BMW with E34,they fitted a two piece manifold.
Youth is wasted on the young.
Thu Feb 25, 2010 7:21 pm
It will still sound shit.
jollygreen
Thu Feb 25, 2010 8:04 pm
thanks for the imput think will stick to tryin to find a decent 318 backbox
jollygreen
actually only need the rear section
