Strut braces - worth it?
the bottom one is for a right hand drive (for my car)
the top one is a left hand drive (bought from germany)
I think
I think
yes battery in boot
Interesting...Barx325i wrote:neither..! twin tubage is the way to go about things imo, but variations like tire pressures, eccentric bushings spring rates, damper rates, moreso driving style! Either could be better.
I prefer the feel of the twin tube, the spacco scaffold type is too harsh especialy on the road & definately increases tendancy to understeer
I have an OMP single tube one at the moment but was going to make a Sparco type...
The thought about making a RD type brace as all they are simple to make.
fastdiablo
Thats what I did . . . a couple of coats of matt black HammeriteBarx325i wrote:you can have a hartge brace for under £160. Not sure that billet ie. virtually no lateral damping is right for the chassis, but saying that I've never used one. Sparco is well worth it at £60 and £5 for a can of halfords black
they eiminate tower shake on the limit of turn in and do make a difference, but as said, the rest of your system need to be tip top before considering a brace to improve stuff
I reject your idea of reality and replace it with my own
- Homo Hair
- Contact:
My 'sparco style' one isn't too harsh neither does it make the car understeer.. A strut brace isn't going to make a car understeer, unless the shell was flexing so much without the suspension geometry was changingBarx325i wrote:neither..! twin tubage is the way to go about things imo, but variations like tire pressures, eccentric bushings spring rates, damper rates, moreso driving style! Either could be better.
- BEERBOY123
Great, where do I get one of these, how much and can I fit it myself without any special tools? For a 1990 318is.oomz1975 wrote:mmmmm.......very nice.e30topless wrote:one of theseDave_M3 wrote:
Right!!! strut braces...
Which ones do people think is best?
Strong sparco single tube
Or something like the RD hinged brace straight across the engine![]()
Ta
If they arn't so good I guess manufactures wouldn't put them on vehicles as standard equipment . I guess different vehicles have different needs, some may benefit from using a strut brace more than others. Also the qaulity of the brace is another factor.
