Are these MOT fail Items (update It F**King Failed)
Thu Jul 30, 2009 4:29 pm
No i do things properly :wink:
do youy recon if i have a run down to my local dealer they may have adjusters in stock??
all i need is the white plastic bit so the MOT man can adjust them with a screw driver
Thu Jul 30, 2009 4:33 pm
Temporary fix innit :)
Worth a try if it's not too far away
Ollie_bwoii
Thu Jul 30, 2009 4:43 pm
Local dealer, local motor factors, local GSF store etc......
MrWhite
Thu Jul 30, 2009 4:45 pm
I don't think you'll have any luck getting just the plastic part. The whole adjuster comes as an assembly and they are about £6 each. Total rip off!
rust never sleeps
Thu Jul 30, 2009 5:24 pm
£6 each 8O 8O
ive managed to adjust them with a pair of plyers and now ive relised that you can adjust them by turning the hydrolic headlight adjust thing aswell :x wish i had known at the mot then we may have got them near enough :wink:
hopefully it will go back in for test on saturday
hennabm
Thu Jul 30, 2009 6:08 pm
Alex wrote:Went in for MOT
And failed on the following
Nearside Headlamp Aim Too Low
Offside Headlamp Too Low
Advisorys ( although he said he is doing me a favor advising these but they should All really be on the fail sheet as most are badly fooked)
offside inner track rod end ball joint has slight play
Nearside Front suspension arm rubber bush has deteriation
Offside Front suspension arm rubber bush has deteriation
Nearside rear Subframe Bush Deteriorated
Offside rear subframe bush Deteriorated
He recons the rear subframe bushes have been like that for a few years as there basically they are non existant
Just going to go and sort the lights out now
:x :x :x :x :x :x :x :x :x :x :x :x
A bit of a pain to do the bushes but the first advisory "
offside inner track rod end ball joint has slight play" is not a testable item can can only be an advisory item.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Thu Jul 30, 2009 6:15 pm
it should of failed, He did me a favor they are pretty much non existant :(
i think ive managed to sort the lights so hopefully with a bit of luck it will pass
the track rod end has made one wheel wobbly though :?
hennabm
Thu Jul 30, 2009 6:52 pm
The first advisory states - offside inner track rod end ball joint has slight play. To me that reads to be the joint in the steering rack boot, not the one at the wheel end.
If that is the one the tester is meaning he CANNOT fail it for play in that joint as it is not part of the MOT checks.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
Thu Jul 30, 2009 6:55 pm
dont know, need to have a proper look myself
last year the steering rack was an advisory :? :mad:
just orderd some new genuine bmw front wishbone bushes off parts auction, cost £50 for the 2 :)
Thu Jul 30, 2009 8:44 pm
where the plastic adjuster breaks of take it all off and you can get a small spanner on whats left.
that's what i did loads a wd also
Thu Jul 30, 2009 8:46 pm
Alex wrote:dont know, need to have a proper look myself
the eccentric ones are £25 or so posted from cotswold :mad:
Thu Jul 30, 2009 9:14 pm
Oh well its done now :mad:
Whats eccentric mean and do ??? :)
i'am thinking what other bushes could be replaced while i'am at it winkeye
hennabm
Thu Jul 30, 2009 9:20 pm
Eccentric means off set and they are the M3 type that fit straight into std lollipops.
The visual difference is that the std lollipop bushes have voids and the M3 are eccentric and solid.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
Thu Jul 30, 2009 9:22 pm
so basically stiffer, oh well ive got some normal ones comming :)
is there anything else worth doing while i'am at these or should i say someone else at these winkeye
Dezzy
CR24v it's a lifestyle
Thu Jul 30, 2009 10:04 pm
They adjust the caster angle make a vast difference in turn in. Improve handling vastly. As many bushes you can afford to change change mate. Bottom arms, trailing arm bushes, beam bushes, top mounts the more you change the better your car will feel. Thats what I have done so fingers crossed when it's finished it will feel brand new
Thu Jul 30, 2009 10:31 pm
ive got recipts for new top mounts at the back a couple of years ago so hopefully they will be good.
rear beam bushes will get done, front wishbone bushes,
which are the bottom bushes and trailing arm bushes :o: :o:
i'am a bit vauge when it comes to suspension :o:
Dezzy
Thu Jul 30, 2009 10:52 pm
Trailing arm bushes are where the trailing arms bolt into the rear beam. Bottom ball joint is on track control arm
Thu Jul 30, 2009 10:56 pm
just had a look on real oem i think i know what your on about lol :o: :D
Bob_S
Thu Jul 30, 2009 11:44 pm
typical e30 then alex
Bollocks to this 24v scrap!
Thu Jul 30, 2009 11:46 pm
Bob_S wrote:typical e30 then alex
Oh yes, No galvanised bushes in this one :wink:
Bewdley320T
Thu Jul 30, 2009 11:54 pm
That tester isn't much of a mate and in my humble opinion needs f*****g. He's quite happy to fail it on headlight adjustment and let vital suspension faults that could (in theory) get you killed, go as advisories. I'd have been happier if he'd done it the other way round.
Fri Jul 31, 2009 12:06 am
Bewdley320T wrote:That tester isn't much of a mate and in my humble opinion needs f*****g. He's quite happy to fail it on headlight adjustment and let vital suspension faults that could (in theory) get you killed, go as advisories. I'd have been happier if he'd done it the other way round.
well its better than having to replace everything for a re test :roll:
he knows i'am going to get it done, and has said it himself that i NEED to get it done straight away, and in fairness a headlight did fall out when he was playing with it :o:
Bob_S
Fri Jul 31, 2009 12:08 am
well.. he should have failed it until they had been done. Your car is dangerous end of.
Fri Jul 31, 2009 12:09 am
Well done :clap:
Bob_S
Fri Jul 31, 2009 12:30 am
Alex wrote:
Bob_S wrote:
Alex wrote: well its better than having to replace everything for a re test :roll:
Well done :clap:
then again.. it is an iS so the chances of it moving anything more than a snails pace are relatively slim.. a bit like a piece of paper?
Fri Jul 31, 2009 12:32 am
Bob_S wrote:
Alex wrote:
Bob_S wrote: well.. he should have failed it until they had been done. Your car is dangerous end of.
Well done :clap:
you must be mistaken, the sheer torque of the m42 powerd cars around the world is what spins the earth around :)
Bob_S
Fri Jul 31, 2009 12:34 am
Alex wrote:
Bob_S wrote:
Alex wrote:
Well done :clap:
I think you'll find that if you listened in school, you would have learnt something..
run of the mill 4 pot bmw's are gay.
Fri Jul 31, 2009 12:37 am
Oh yes the m3 is gay :eek:
Ive been in a 2.8 m52 converted e30 and i want one, but the IS is staying as is, i will get another e30 for 6 pot rightness :wink:
Bob_S
Fri Jul 31, 2009 12:42 am
Alex wrote:Oh yes the m3 is gay :eek:
M3 isnt exactly run of the mill.
2.8 e30's? sooo last month.
Fri Jul 31, 2009 12:44 am
omg he's at it again.
Fri Jul 31, 2009 12:45 am
i suppose what ever i say you will say the opposite :roll:
Bob_S
no, your just slow on the uptake :)
Fri Jul 31, 2009 12:46 am
Bob_S wrote:
Alex wrote:
Bob_S wrote: M3 isnt exactly run of the mill.
so whats sooo this month then........ :mad:
Fri Jul 31, 2009 12:48 am
Alex wrote:
Bob_S wrote:
Alex wrote: i suppose what ever i say you will say the opposite :roll:
chris-w :wales:
Fri Jul 31, 2009 12:49 am
magpie wrote:
Alex wrote:
Bob_S wrote: no, your just slow on the uptake :)
chris-w :wales:
8O you like blokes mick
:snigger:
