struggling re fitting rear window surround!!
Any help appreciated, have recently had the car resprayed currently re-fitting rear windows (its a coupe) thye metal window surround is meant to push in between the window seal but i cant for the life of me get it to locate in the channel. Is there a knack to this ie taking window out and fitting surround then re-fit to car, any help, tips, opinions welcomed!!
- Brianmoooore
Black rubber ones can be refitted with a couple of screwdrivers, at great risk to the paintwork, but, if it's the metal type filler, then you really need to get the special tool for the job.
- fran_d_318is
take the window out and u can then bend the rubber and push the metal frame ting in
i spent hours trying to do it wit the window in and wen i took it out it took 10 min
poolnoodle
The correct tool to do this costs next to nothing and takes about 10 minutes
