head
konflik1
Wed Jan 28, 2009 1:25 am
i have just bought a m20 2.5 engine and it has an 'ANC' stamp on the head.can someone tell me what this means?
reggid
Wed Jan 28, 2009 1:49 am
Spanish aftermarket casting possibly
E30 325is with M20B31
maggspower
Turbo Farmer Tractor Driver
Wed Jan 28, 2009 1:58 am
It actully says "AMC" I think.
It is a replacement head, i.e not bmw. Having said that they are good quality casting, the ports are not finished quite as well as the bmw, but otherwise they are on a par, except for one thing. They don't crack like the bmw one :D which is a huge peace of mind.
Its funny you mention it as I have just rebuilt one today!! It will be up for sale tomorrow if anyone would like it.
cheers maggs
zaust
Zone day release
Wed Jan 28, 2009 8:22 am
The one I got from corry racing was amc. has stronger journals and stronger wider water way's. Corry's did sort the roughness of the casting out before it was in my hands though winkeye .
M30 Tech 1 Touring on gas.
konflik1
Wed Jan 28, 2009 9:25 am
thanks for the info so far.the guy i bought the engine from says it it 2.5 ported to 2.7 is there anyway in finding this out?
zaust
Zone day release
Wed Jan 28, 2009 9:50 am
Mesuering the stroke of the piston from tdc down. Someone will post up the throw for you i'm sure.
maggspower
Wed Jan 28, 2009 10:31 am
If you have the engine out of the car the best bet would be to take the sump off and have a look at the crank.
If it is a 2.7, the crank will be stamped with "HUB 81" somewhere. I cant quite remember where but I'm sure it on one of the counter weights.
Thid means the crank has a stroke of 81mm, instead of 75mm. These cranks come from either the e28 525e engine, or a diesel engine the m21, from the 5/324td
the other way to check would be look inside the ECU if you have it, it will have a different chip in it, but this is less conclusive than taking the sump off.
Good luck, hope youve got a 2.7 :D
konflik1
Thu Jan 29, 2009 1:49 am
thanks maggs i sure hope i have one too.really looking forward to to converting from my m40 1.8 to this '2.7'
