To add to all the cosmetic stuff you've done/plan to do your car, sort the suspension and brakes first. Never mod for power first. That's going arse end first. And if you want cheap speed work on the power to weight ratio of the car. Loading it up with electric gizmos and body kit stuff adds a lot of weight and sucks performance out of the car. Taking a little weight out of the car is essentially free power. And you can't get cheaper than free.Alex wrote:some nice mods there
4.10 lsd i bet that took some finding
is it worth removing the heater plate????
mods ive done:
13 button obc (needs fitting)
map light mirror (needs fitting)
dye carpets dark grey
fit unworn tech 1 wheel
new bmw gear nob
new gear gator
get my 15" bbs refurbed with new center caps
de chromed leccy ariel
fit tweeter pods along with comps amp etc etc
fit tech 1 spoiler
clear side and front indicators
service
the list goes on
still got loads more to do
the plan is to spec it up as much as possible
Throttle bodies are a sensational thing and a joy forever but on a stock engine there really isn't much point. If you are after throttle response (and you will get bags of it form ITBs) have a think about a BBTB and porting the inlet manifold. Much, much cheaper and the throttle response is excellent. You'll get a few horsies, too. Match that with a chip and a free flowing exhaust and you'll be on your way.
