Steering coupling e30 318i
Greener
Mon Jan 12, 2009 2:31 pm
I have just changed over from power to manual steering rack and have discovered the steering coupling is to short, does anyone know if its just a case of getting a complete new coupling or are they broken down as individual pieces ie just purchase a longer shaft.
Any help appreciated or if anyone has one for sale?
Thanks Alex
DHFiS
Mon Jan 12, 2009 6:03 pm
You can seperate the coupling by grinding the heads off the rivets through the rubber section. Once splint into 2 parts make a spacer to bring it to the correct length and replace the rivets with bolts. For safety's sake I'd use Nylock nuts on the new bolts.
Mon Jan 12, 2009 6:04 pm
Just get a coupling from a manual steering car
Chris-W
Mon Jan 12, 2009 6:05 pm
The manual racks use a different and significantly longer steering coupling.
Theo
Mon Jan 12, 2009 6:07 pm
That's not actually true; the splined pinion is a different size on the manual rack, you will need the complete linkage from a manual rack.
DHFiS
Mon Jan 12, 2009 6:11 pm
DanThe wrote:Just get a coupling from a manual steering car
That does sound much easier than what I suggested
Theo
Mon Jan 12, 2009 6:21 pm
Wow, I must have taken along time to type that short reply, it was in response to DHFiS's post!
Greener
Tue Jan 13, 2009 3:11 pm
thanks for clarifying guys...i dont suppose anyone has one for sale?? winkeye
