Well lads and ladies apon discussion with my missus we have agreed to put my impreza back on the road, what has this to do with e30zone, well she also said i may have a nice e30 project to pass the time after i finished my scooby which should be a month or two, now what i want to know is what are my options, i want a straight 6 thats for defo and i would prefer a 2 door coupe
what im looking at is
my options with regard to engine, box and diff setup
cost for said setup
ease of setup to fit into e30 chassis
many thanks for any help.
Project options
zimm_zimmer
- Contact:
will b
What will you be using the car for?
For a straight 6 you want a minimum of 2.5L (speaking as a 2.0 driver) then you have to decide weather you want the newer 24V lump or not, the older 12v M20 can be run above 400bhp on standard internals with a turbo
zimm_zimmer
- Contact:
well i had 2 m20 325i and they were greatl, i already have a turbo impreza so to be honest would like something with the power there all the time or perhaps supercharge it later on, i would like a later 24v engine but i dont know which one to use i.e should i use a 2.5 or should i go the whole hog and get an m3 lump??
I dont really have a budget as all work will be done by myself being a mechainc but i dont have the money to go wild, i would say i could budget a 24v conversion with obvious uprated brakes being involved.
What is needed for the 24v conversion? And what is complexity
will b
BadDave
From what i've read/heard they can run up to 600bhp on standard internals with uprated headboltsstonesie wrote:
Cheapest power/£££££ option would be to slot in a M20B25 tbh
The M50/M52 option is going to be more expensive. and the M3 option you mention will cost upwards of £5K IIRC for all the necessary parts and fitting if basing it on an E36 evo/non evo lump
Have a look at the M50/M52 sticky for details and on E3024V when it's back up and running(it's curently down coz there switching servers IIRC)
zimm_zimmer
- Contact:
in all honesty i do know and like more about the m20 b25 lump than the 24v lump, so what would be better/value wise turbo or supercharger, i know a supercharger would cost more as there is more of a setup but what sort of engine management would i need to run the turbo on it and what sort of size turbo should i run, i dont want something to laggy but dont want something thats gonna run out of puff early in the rev range.
will b
GrindCulture
M50s are pretty strong when it comes to turboing too. I'd go for an M50B25 with a big Holset turbo stuck on it all day long.
Not in E30s any more
zimm_zimmer
- Contact:
what is the difference between the m50 and m52? i have looked and both seem like the same 24v outta a e36/e46
will b
