air-con option???
josh-hocking
Teenager with Taste !
Wed Aug 06, 2008 9:22 pm
hi
im thinking of adding air con to my car. what i wanted to know is how hard is it?? what do i need and would the 2325 radiator be the same??
thanks
josh
maxfield
Wed Aug 06, 2008 9:25 pm
I can't see it being that difficult.
Assuming you get everything you need or you will find you need odd bits and bobs here and there.
You do realise it drains your fuel and makes your car feel asthough the handbrakes on?
Wed Aug 06, 2008 9:29 pm
maxfield wrote:I can't see it being that difficult.
only on m40s :wink:
josh-hocking
Wed Aug 06, 2008 10:02 pm
thanks for the comments!! i didnt reliase it would slow it down that much :eek: :eek:
Wed Aug 06, 2008 11:14 pm
josh-hocking wrote:thanks for the comments!! i didnt reliase it would slow it down that much :eek: :eek:
i cant imagine there being much difference
if you really want it get it :D
to be honest i really dont like not having air con to me a/c would be more usefull than say pas
Steve-E30
East Sussex Hooligan
Wed Aug 06, 2008 11:17 pm
You will hardly notice the difference , Didnt spadge have a complete set up recently ??
Might be worth dropping him a pm
Giggety Giggety Goo!!!
Wed Aug 06, 2008 11:24 pm
Air con is a good upgrade and well worth having
Niiick
Wed Aug 06, 2008 11:53 pm
It's a different radiator to the standard fitment.
josh-hocking
Thu Aug 07, 2008 11:18 am
cheers so would i need a set up for a 318i??? or are they all the same?
as to the kit a mate of mine is selling his car as spares and it has it so i might have that :)
thanks
josh.
also is the 325 radiator differnt to the 318i?
thanks
josh
gazza
Thu Aug 07, 2008 12:24 pm
josh if you have a after market rad then check on the o/s for a brass plug where a temp switch goes for the air con (its not totally neccesary)most of the kit is the same there are those that say a 325 set up into a m40 will not go but other than the alloy mount to the engine block and the 2 pipes that connect to the compressor there are only minor differences(my 325 has a kit from a 318 fitted) bought almost complete from a scrappy for £50 (i was v lucky)
the worst bit is the dash needs to come out to fit the a/c heater box
harry_p
Thu Aug 07, 2008 12:49 pm
aicon only saps power while it's on, when off the clutch on the compressor makes it free rolling. even when on it probably only takes a bhp or two to run.
cheers,
harry
