short shift
Tue Jul 29, 2008 10:21 pm
Elecblondie
Tue Jul 29, 2008 10:46 pm
That's been around for quite a while. Does not look like the best way of doing it at all does it. Fine if you're prepared to have to retighten it all the time I guess.
Tue Jul 29, 2008 10:50 pm
I just tought it was a cheap idea myself.I've put the z3 shifter on mine which is probably 100 times better than that! :mad:
Elecblondie
Tue Jul 29, 2008 11:59 pm
Yeah, I've got the UUC Motorwerks one thanks to the previous owner. It's cheap but realistically if you want to make something rigid putting a joint in it like that isn't really the way forward, especially as it's not that much cheaper than the other ebay ones with a full lever. I guess you don't have to do much work to install it is the only advantage.
Wed Jul 30, 2008 9:39 am
Still a very crude idea.
Someones brainchild i suppose :mad:
**BANNED**
Wed Jul 30, 2008 11:30 am
I fitted one of these about 18 months ago and find it very good.Well made and does just what it says on the box. It has not work loose or needed re-tightening.Seem to remember that I only paid about £12 though...It is also worth replacing the linkage bushes to reduce slop and play in the gearshift.My wife moans about the short shift, she claims that it is heavy and difficult to use compared to the standard item in the touring.I just keep suggesting that she should fully depress the clutch and drive the car far enough to let the oil warm through.I found that using ATF in the gearbox made a significant improvement to the weight of the gearchange,and I would guess that a heavier gearknob would lighten it further.
Youth is wasted on the young.
gooner1
Out humping Reindeer
Wed Jul 30, 2008 5:14 pm
May well work but this claim is bollo*.
no need to remove the stock shifter as other competitor models (without proper BMW tool it is kind of impossible to remove the stock shifter from the housing).
tommtb
Wed Jul 30, 2008 5:16 pm
how much did you pay for your Z3 shifter, is it spot on?
cheers
Jon_Bmw
Dangerous when thinking
Wed Jul 30, 2008 5:27 pm
Moving the pivot point is the way it is changed on a 205 gti. We have done it on ours and had no problems. Haven't really had the inclination to mess about with the e30 one.
Wed Jul 30, 2008 8:19 pm
Paid £23.00 from the stealers and works well as it should. :cool:
oakey
Wed Jul 30, 2008 8:42 pm
^ I have got a z3 lever in mine and it took me a while to get used to, although after an hour or so I decided that it feels much better than the old lever. It seems much tougher to take it out of reverse position though.
Wed Jul 30, 2008 8:57 pm
agreed it is a bit stiff in reverse, but still worth it :cool:
