Has this been tried?? if not do you see any problems.
Any input greatly appreciated
Charlie
I'd be tempted to say your coil overs are too stiff for road use, more useful for track work.. your effectively floating above the road surface which is giving you this feeling.nadz325i wrote:me thinks over sized?? overstiffned unless matched to shocks springs even.
i have hr bars and coilovers and the m3 cant corner well at all, understears then tends to overstear.. scary. with some research people reports the bars are over stiffening the body hence the effect.
not sure but im testing the theroy by reverting back to original.
i would say depends on spring rates but hey who know, might work out for you.
From my ETK the compact is as follows:Bob_S wrote:I dunno mate.. could always grab a pair, are they standard fitment on any compact?
how can 1 determine from upgrading to softer springs or replacing ARB with smaller diameter roll bar (22/21mm front to 19mm and 18 to 14.5 rear)??I'd be tempted to say your coil overs are too stiff for road use, more useful for track work.. your effectively floating above the road surface which is giving you this feeling.
