Theo325 wrote:Not that I really know much at all about dynoplots and the like, but you seem to have quite low transmission losses judging by the difference in WHP and EHP. When Paul did a power run on my turd last april it had 40 and then 46 hp losses on it's two runs. It did transpire that my gearbox didn't ANY oil in though!
Theo, when you were here our dyno was litterally less than a week old. The dyno was still tight and hence high losses were measured. Now the dyno has seen alot more work, power at the wheels have increased. Power at the flywheel will be the same if nothing has changed
Ste, it was nice to meet you and as you saw we had great gains while live mapping your car with your old Unichip but there was a hitch with it which stopped further progress. Fingures crossed we will find a solution to the hitch over the next couple of days and reassure you with what the Unichip and your M52B28 is capable of.
The torque curve is a little wavey, but this is seen or highlighted on our dyno as the graph is autoscaled. If the torque started at zero and not 160 then the curve would be much smoother.
Also it was weird to see the lambda sensors were still working under full throttle upto 3500 rpm. This is very unusual as normally the lambda sensors are ignored by the ECU when full throttle is applied. The wavey and poor torque line upto 3500 is the lambda sensor still working and causing rapid adjustments in AFR's.
www.sabre-tuning.co.uk
