Steering Rack Conversions
Revision as of 17:14, 16 July 2008 by March109 (talk | contribs)
Schuy - this one could be for you!
This is more for the UK and Australian (Right hand drive) guys. Probably still valid for the US guys as well.
I have been working on fitting an E36 M3 rack on my 325i Sport. For anyone who read the article on the Zionsville Autosport website (before they decided to sell the info on CD), It is a relatively easy conversion, apart from messing around shortening the Rack to steering column joint.
Zionsville came up with a (not very pretty) solution that I was never all that happy with. I had thought about doing this for a while, but there was no info about doing it to a RHD car. Also, the type of joint that Zionsville modified, is not available in the UK (to my knowledge). Since my engine was already out, I figured now was the time to have a go.
Mounting the rack to the car is basically a straight swap for the E30 rack. You need to use a couple of spacers (approx 14mm) as the mounting points on the E36 rack are not quite as tall as the E30 ones. The spacing of the bolt holes is identical though. You could either make up some spacers, or pack it out with washers. Either would work.
The E36 rod ends bolt straight to the E30 steering arms, so no problem there. You could probably use the E36 power steering pipes with a bit of modification (bending), or have custom pipes made. I chose the latter solution.
Now for the rack to column joint. I think I have found a more elegant and stronger solution (in my opinion) to the Zionsville version.
You need to combine the upper UJ from the E30 joint, and the lower UJ from the E36 joint. You also need to make an Aluminium or Steel spacer to join them together. The standard E30 joint is approx 275mm long. This needs to be shortened by 25mm to 250mm long.
Now, back to the hole in the disc. This is for the centering bush (similar to the nylon one on the E30 joint). If you look at the pinch bolt section you removed earlier, you should see a bronze bush in the centre. This is retained by some deformations (stakes ?) in the housing. With some careful drill work, the bush can be removed. It also helps if you cut through the side of the housing and open it up with a chisel. You need to make the hole in the centre of your new metal disc the same as the O/D of the bush. It needs to be a snug fit, and can be retained with some bearing securing solution (Loctite etc).
Click here to download the zip file
