Basic M40 Servicing
Revision as of 13:04, 16 July 2008 by 86.9.30.229 (talk)
M40 Engine - Basic Servicing
Scared of the Spanner?!
This guide was made for you!
Coolant Change 5L of Coolant (mix it 60/40 water/antifreeze)
Large Flat Blade screw driver for releasing bleed screw
Oil Change
Spark Plug Change
4x Spark Plugs, preferably NGK brand (NGK BPR6ES)
Masking tape + pen
19mm Spark plug tool
Overview of an m40
Do the coolant first…
        • Disconnect Battery****
Oil change is easy...
Spark plugs...
