Lollipop Bushes
Revision as of 08:48, 27 June 2014 by Grrrmachine (talk | contribs)
These are the bushes I chose....
2. Then remove the ball joint that attaches the wishbone to the back of the hub, its best to use a ball joint splitter for this, I used the scissor type and found it relatively easy, but how you do it is up to you. You will also need to disconnect the ARB drop link from the underside of the wishbone..
12. Now apply plenty of copper grease to the ridged part of the puple inner bush (do NOT use grease if you're using rubber bushes!). Then press in to the centre of the lollipop so you have this...
13. Apply a liberal coating of copper grease to the wishbone where the bush is pressed on,
and it should now be relatively easy to push the lollipop/bush assembly back on to the rear of the wishbone. I used a block of wood and a hammer to knock it on. Make sure you knock it all the way on or it will be very difficult to do the lollipop bolts back up again.
Note: if fitting M3 Lollipop bushes, pay attention to the placement of the hole, relative to the lollipop shaft.
14. Now bolt the lollipop back into position, refit the ball joint, ARB drop link etc, and you're done!!!
