M6x
Revision as of 12:14, 31 March 2013 by Grrrmachine (talk | contribs)
The BMW M6x range of engines are a line of V8 DOHC piston engines which were produced from 1992 to 2005. The first version, the M60, was the first V8 engine BMW had produced for 25 years. This was replaced by the M62. Together, the engines were used in various BMW models (E31, E32, E34, E38 & E39) and were also sold to other manufacturers to use in their cars.
The M60 was in development from as early as 1984. One of the the main aims of the development process was to reduce the size and weight of the engine, and CAD was used extensively to aid this.
As a Motorsport engine, the M62 was designated S62, and saw action in the E39 M5 and the roadster Z8.
If you want one of these beasts under your bonnet, learn more about the M6x engine swap.
All M6x engines consisted of aluminium cylinder blocks and cylinder heads and then plastic inlet manifolds. They were also DOHC with four valves per cylinder.
M60
The M60 engine was driven by a dual-row timing chain. Valves had hydraulic lash adjustment to reduce maintenance, and the camshaft chain drive was self-adjusting. There was no distributor, each cylinder having its own ignition coil. Fuel injection and ignition are controlled by the Bosch Motronic 3.3 system. There was a 3.0l and a 4.0l version of this engine. It's worth noting that these engines used the famous Nikasil cylinder bore linings.
M60B30 3.0 L (2,997 cc (183 in³)) 160 kW (218 PS; 215 hp) @ 5800 290 N·m (214 lb·ft)) @ 4500 6500 1992
M60B40 4.0 L (3,982 cc (243 in³)) 210 kW (286 PS; 282 hp) @ 5800 400 N·m (295 lb·ft)) @ 4500 6500 1992
M62
Added to the BMW range in 1996, the M62 was largely the same as the M60 with just a few revisions. The timing chain was now a single-row timing chain, Alusil replaced the Nikasil cylinder liners, and in 1998 VANOS was added.
There was 4 different capacities of the M62 offered, two of which were later available with VANOS. The VANOS engines were given the designation of M62TU.
Engine Code Displacement Power Torque Redline Year
M62B35 358S1 3,498 cc (213 in³) 173 kW (232 hp) @ 5700 320 N·m (236 lb·ft) @ 3300 6200 1996
M62TUB35 358S2 175 kW (235 hp) @ 5800 345 N·m (254 lb·ft) @ 3800 1998
180 kW (241 hp) @ 5800 345 N·m (254 lb·ft) @ 3800 1998
M62B44 448S1 4,398 cc (268 in³) 210 kW (282 hp) @ 5700 420 N·m (310 lb·ft) @ 3900 6100 1996
M62TUB44 448S2 210 kW (282 hp) @ 5400 440 N·m (325 lb·ft) @ 3600 1998
M62B46 468S1 4,619 cc (282 in³) 255 kW (342 hp) @ 5700 480 N·m (354 lb·ft) @ 3700 6500 2001
S62B50 508S1 4,941 cc (302 in³) 294 kW (394 hp) @ 6600 500 N·m (369 lb·ft) @ 3800 7000 1998
