M6x
Revision as of 03:18, 3 March 2013 by Kedge (talk | contribs) (New page: right|250px The BMW '''M6x''' range of engines are a line of V8 DOHC piston engines which were produced from 1992 to 2005. The first version was the M60 and was this ...)
The BMW M6x range of engines are a line of V8 DOHC piston engines which were produced from 1992 to 2005. The first version was the M60 and was this first V8 engine BMW had produced for 25 years, this was then replaced by the M62. These engines were used in various BMW models (E31, E32, E34, E38 & E39) and were also sold to other manufacturers to use in their cars.
The M60 was in development from as early as 1984, one of the the main aims of the development process was to reduce the size and weight weight of the engine and CAD was used extensively to aid this.
All M6x engines consisted of aluminium cylinder blocks and cylinder heads and then plastic inlet manifolds. They were also DOHC with four valves per cylinder.
M60
The M60 engine was driven by a dual-row timing chain. Valves had hydraulic lash adjustment to reduce maintenance, and the camshaft chain drive was self-adjusting. There was no distributor, each cylinder having its own ignition coil. Fuel injection and ignition are controlled by the Bosch Motronic 3.3 system. There was a 3.0l and a 4.0l version of this engine. A final thing to note, these engines used the famous Nikasil cylinder bore linings.
M60B30 3.0 L (2,997 cc (183 cu in)) 160 kW (218 PS; 215 hp) @ 5800 290 N·m (214 lb·ft)) @ 4500 6500 1992
M60B40 4.0 L (3,982 cc (243 cu in)) 210 kW (286 PS; 282 hp) @ 5800 400 N·m (295 lb·ft)) @ 4500 6500 1992
M62
The M62 was largely the same as the M60 with just a few revisions, the M62 was added to the BMW range in 1996. The timing chain was now a single-row timing chain, Alusil cylinder liners and later Vanos was added in 1998.
There was 4 different capacities of the M62 offered, two of which were later available with Vanos, the Vanos engines were given the designation of M62TU.
Models
Engine Code Displacement Power Torque Redline Year
M62B35 358S1 3,498 cc (213 cu in) 173 kW (232 hp) @ 5700 320 N·m (236 lb·ft) @ 3300 6200 1996
M62TUB35 358S2 175 kW (235 hp) @ 5800 345 N·m (254 lb·ft) @ 3800 1998
180 kW (241 hp) @ 5800 345 N·m (254 lb·ft) @ 3800 1998
M62B44 448S1 4,398 cc (268 cu in) 210 kW (282 hp) @ 5700 420 N·m (310 lb·ft) @ 3900 6100 1996
M62TUB44 448S2 210 kW (282 hp) @ 5400 440 N·m (325 lb·ft) @ 3600 1998
M62B46 468S1 4,619 cc (282 cu in) 255 kW (342 hp) @ 5700 480 N·m (354 lb·ft) @ 3700 6500 2001
S62B50 508S1 4,941 cc (302 cu in) 294 kW (394 hp) @ 6600 500 N·m (369 lb·ft) @ 3800 7000 1998
