Z1
Revision as of 23:21, 15 February 2013 by Grrrmachine (talk | contribs)
The BMW Z1 is a two-seat soft top roadster. It uses the engine and transmission from the E30 325i mounted in a specially designed base frame or chassis, which is made from galvanised steel. The sports body, which is made from various types of composite resin panels, is fixed onto the base frame. The front Suspension is re-worked 325 components, with a wider track. The rear suspension is the specially designed 'Z axle'.
The most distinctive features of the body are the electrically powered doors, which in the open position drop down into the side sills, this creating the ultimate 'open car' when the soft top is lowered underneath its flat cover.
Compatible Parts
Engines
Main article: Engine Swaps
Wheels
