Aircon
The aircon installation is essentially the same across the E30 range. However, different compressor-mounting brackets and pipework lengths mean that kits are not completely interchangeable between models.
Compressor
The compressor itself does not pump continuously. Instead, it is activated based on the internal pressure of the system and whether or not the Aircon is turned on. That way, the compressor does not sap precious power, and therefore fuel, from the engine when it's not wanted.
Since the refrigerant is constantly changing between a gas and a liquid throughout the system, by the time it meets the compressor it is in a gaseous form. The compressor, unsurprisingly, compresses this gas which makes it hot, before pumping it on to the condenser.
Aircon Clutch
Condenser
The condenser's location and construction make it one of the most fragile elements of the installation. Not only can it be damaged by road debris, but it is also exposed to road spray at its base, leading to rust. This makes them the prime source of refrigerant leaks and therefore total system failure.
Fan
Evaporator
Expansion Valve
Pipework
Receiver Drier
Pressure Switch
Mounted into the receiver drier will be one or two pressure switches, depending on which refrigerant is used. For early R12 systems, two switches detect the high and low pressure of the system. If the pressure is too low, usually caused by a lack of coolant, then the switch prevent the compressor from charging the system. If the pressure is too high, the compressor is again shut off to reduce the pressure. In the R-134a systems, these two switches are combined.
Refrigerant
R-134a Kit
The R-134a kit includes a new receiver drier, valves, pressure switch and some O-rings, like so:
Since the kit combines the two pressure switches of the old system into one new unit, the wiring has to be customised to join the signals together. You need to short out the wiring for one of the old switches and solder the new plug supplied in the kit to the wires for the other old switch, connect the new plug to the new switch.
Alongside the primary Aircon components, there are other parts that work in conjunction with the aircon to make the car work better.
Because of the location of the condenser, the existing radiator is normally a modified unit. Aircon-specific radiators have a different profile, making them deeper as well as taller to provide a larger cooling area. Their height means that their bottom protrudes further down into the valance.
Aircon radiators will also feature a boss (or bolt hole) for the fitting of an extra coolant temperature sensor. This allows the aircon to monitor the temperature of the radiator and increase the speed of the aircon fan if necessary, to prevent overheating.
Two sizes of radiator were available, and are known as UK and Tropical radiators. While not essential to the running of aircon, it is recommended to fit a tropical radiator to minimise the risk of overheating. However, it is possible to install aircon and keep your existing radiator, as long as it has the boss for the temperature sensor.
Valance
To help with the overall cooling of the radiator and condenser, special aircon-specific front valances were fitted to cars with factory-installed aircon. These valances feature an extra cutout (with no blanking plate or grille) to allow more air to flow over the bottom of the radiator.
If you are retrofitting aircon it is not essential to install the aircon-specific valance, but you must ensure that your radiator, condenser and fan are in good condition.
Installation
Aircon Won't Turn On
