Engines Troubleshoot
Revision as of 07:18, 16 February 2012 by Grrrmachine (talk | contribs)
Troubleshoot
START | ||||||||
test bulb on coil | bridge wire to coil | green wire | ||||||
Does it glow? | → | Immobiliser? | → | OBC? | → | Check for 12V at ECU | ||
Does the engine crank? | → | → | → | Does it try to start? | → | Pull out Fuse 11 | ||
Does the battery have 12V? | → | charge battery | ↓ | Does it try to start? | → | ↓ | ||
↓ | ← | Does the ICV buzz
with ignition on? |
↓ | ↓ | ↓ | Test Blue Temp Sensor | ↓ | ||||
Diagnostic Plug Start | Bridge the DME Relay | → | Does the fuel pump
run when cranking? |
↓ | DME Relay | Check Fuse 11 | ↓ | ↓ | ||||
↓ | Fuel Pump Relay | ← | Bridge the Fuel Pump Relay | Fuel Pump | ↓ | ↓ | ||
Does the engine crank? | → | Ignition Switch | Connect bulb across Fuel Pump pins | → | Does it glow? | ↓ | ↓ | |
Starter Motor | Test CPS | ← | ← | ← | Check for spark | ← | ↓ | |
Check for air leaks | ← | ← |
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
There's a green wire, the sneaky fuck
