Engines Troubleshoot
Revision as of 20:44, 15 February 2012 by Grrrmachine (talk | contribs) (New page: Nightmare. Your engine won't start! Dry your eyes and pick up your tools, we'll get her going again. __NOTOC__ =Troubleshoot= The troubleshooting table is a clickable diagram to help you ...)
Troubleshoot
| START | |||||||
| test bulb on coil | bridge wire to coil | green wire | |||||
| Does it glow? | → | Immobiliser? | → | OBC? | |||
| Does the engine crank? | → | → | → | Does it try to start? | → | Pull out Fuse 11 | |
| Does the battery have 12V? | → | charge battery | ↓ | Does it try to start? | → | ||
↓ | ← | Does the ICV buzz
with ignition on? |
| ↓ | ↓ | ↓ | Test Blue Temp Sensor | ↓ | |||
| Diagnostic Plug Start | Bridge the DME Relay | → | Does the fuel pump run when cranking? |
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
There's a green wire, the sneaky fuck
