Revision as of 21:57, 9 December 2011 by Grrrmachine (talk | contribs) (New page: Alongside the gearbox, the Clutch is one of the most misunderstood mechanical components of the car. But it doesn't need to be __TOC__ =Overview= The clutch m...)
Clutch Disc
The clutch disc
The output shaft of the gearbox is splined, and the clutch disc fits over these splines.
Pressure Plate
Release Bearing
Master Cylinder
Slave Cylinder
