Interior
Revision as of 17:30, 8 October 2011 by Grrrmachine (talk | contribs)
Dashboard
Instruments
Main article: Instruments
Controls
  • Wash/Wipe stalk
  • Indicator stalk
  • Cruise Control stalk - if fitted
  • OBC stalk - if fitted
  • Hazard Lights
  • Rear Wash/Wipe Touring only
  • Heater Controls
  • Rear Demister
  • Air Conditioning - if fitted
  • Electric Windows - if fitted
  • Heated Seats - if fitted
Vents
Seats
Front Seats
Rear Bench
Door Cards
Carpet
E30 Carpet
Headlining
Maintenance
Problems
