Interior
Dashboard
Instruments
Main article: Instruments
Controls
- Wash/Wipe stalk
- Indicator stalk
- OBC stalk - if fitted
- Hazard Lights
- Rear Wash/Wipe Touring only
- Heater Controls
- Rear Demister
- Heated Seats - if fitted
Seats
Front Seats
Rear Bench
