325e
Revision as of 12:30, 8 October 2011 by Grrrmachine (talk | contribs)
325eS
Introduction
325e
325eS
Dashboard Display. 4750RPM Redline.
M20B27
325e Advert from 1984
This is the Eta engine; the 2.7 power-plant, built for economy and efficiency. The older B27 engines used the "200" head, as found in the E21 320/323i and also the E12 520. In the Eta engine, this head was modified, using only four cam bearings rather than seven, very soft valve springs, short duration cam, and small inlet manifold ports. This gave the characteristics of very low revving, and very low fuel consumption, but also very little power. The 200 Eta head was mounted on a long stroke, straight six block. This made an ideal pairing with the head, and despite the lack of power and engine speed, the long stroke produced a great deal of torque across a very wide power band. Later cars, from 1987 onwards, were fitted with a different cylinder head. This was based on the "885" head used in the 325i, and is known as the Super Eta. To accommodate the new head, the engine management was updated to Motronic 1.3, new pistons were made, the intake manifold was made larger to match the larger ports, the rev limit/fuel shut-off was increased to 5300RPM, and the exhaust was fed through twin pipes. The compression ratio was also dropped, owing to some detonation problems when using 95RON fuel.
327i Strokers
A common modification for the E30 is to mate the 2.7 engine block from the 325e, with the cylinder head from a 325i, thus creating a 327i. The torque of the long stroke block is combined with the high power of the uninhibited 885 head, increasing power substantially over the normal Eta engine; from 128bhp to around 185bhp, as well as some torque increase. There are a few methods for doing this modification. For details, see Building a 2.7. Another effective, and much simpler, way to achieve more power from the Eta engine is by fitting a chip. Fuel delivery is increased, and the rev limit is raised. For more details, see the Chip Fitting Guide.
Commercial Success
325e wins Watkins Glen 24hr
The 325e Today
