Doors
Revision as of 20:43, 4 October 2011 by Grrrmachine (talk | contribs)
Doors
Windows
Learn how to retrofit electric windows.
Wing Mirrors
Locks
Main article: Central Locking
Electrics
  • Door locks
  • Door lock heater (if fitted)
  • Wing mirrors
  • Electric windows (if fitted)
Trim
To remove the bump trim, remove the 8mm plastic screw from the inside edge of the door (closest to the lock) and then pull the strip firmly away from the door. It is held on with two plastic clips.
Rust
Electric Windows not working
The electric windows fitted to E30s are a simple mechanism
