Lollipop Bushes
These are the bushes I chose...
2. Then remove the ball joint that attaches the wishbone to the back of the hub, its best to use a ball joint splitter for this, I used the scissor type and found it relatively easy, but how you do it is up to you.
Then tigthen up the vice carefully making sure the bush slides in evenly all the way round. Obviously you will have to sop before the bush is all the way in as the back face of the vice will stop the bush.
