Lollipop Bushes
Revision as of 09:12, 28 February 2010 by Richy187 (talk | contribs)
These are the bushes I chose...
2. Then remove the ball joint that attaches the wishbone to the back of the hub, its best to use a ball joint splitter for this, I used the scissor type and found it relatively easy, but how you do it is up to you.
