Lollipop Bushes
Revision as of 09:07, 28 February 2010 by Richy187 (talk | contribs)
These are the bushes I chose...
 2. Then remove the ball joint that attaches the wishbone to the back of the hub, its best to use a ball joint splitter for this, I used the scissor   type and found it relatively easy, but how you do it is up to you.
 6. You will really struggle to pull this off as its rubber wrapped around a metal ring with rubber inside press fitted over the wishbone. So to make it easier to pull off you need to cut it. I chose an angle grinder (my weapon of choice) you may be able to use a hacksaw but angle grinders are so much quicker... Any way you only need to cut through the metal ring, and be very careful not to mark the wishbone itself
