Basic M40 Servicing
M40 Engine - Basic Servicing...
Scared of the Spanner?!
This guide was made for you!
- Coolant Change
- Oil Change
- Spark Plug Change
- Masking tape + pen
- 19mm Spark plug tool
Overview of an m40
Do the coolant first…
- Disconnect Battery****
Oil change is easy...
Spark plugs...
