Basic M40 Servicing
Revision as of 04:31, 24 November 2010 by Ugirylylov (talk | contribs)
This Page Is Currently Under Construction And Will Be Available Shortly, Please Visit Reserve Copy Page
CLICK HERE
M40 Engine - Basic Servicing..
Scared of the Spanner?!
This guide was made for you!
  • Coolant Change
  • Oil Change
  • Spark Plug Change
  • Masking tape + pen
  • 19mm Spark plug tool
Overview of an m40
Do the coolant first…
        • Disconnect Battery****
Oil change is easy...
Spark plugs...
