Limited Slip Differential
>the links are available in earlier editions of this ...
Limited Slip Differential From E30 Zone Wiki Revision as of 17:14, 26 July 2009 by 91.149.179.60 (Talk) (diff) ←Older revision | Current revision (diff) | Newer revision→ (diff) Jump to: navigation, search
Generally Limited Slip Differentials are referred to as a Slipper or as an LSD. This contrasts to the normal differential fitted that is known as an Open Diff.
E30s with LSD as standard
* 325i Sport * M3
Case sizes
E30 LSD Ratios
* 3.15 - M3 * 3.64 - prefacelft 325i * 3.73 - facelift 325i * 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport * 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case. * 4.27 - * 4.44 -
What these numbers mean
What oil to use for your LSD
External Links
* Wikipedia's Limited Slip Differential Entry * How Stuff Works - Differentials * Video of open and LSD rotation
