Basic M40 Servicing
Revision as of 22:21, 5 February 2010 by Richy187 (talk | contribs)
M40 Engine - Basic Servicing
Scared of the Spanner?!
This guide was made for you!
  • Coolant Change
  • Oil Change
  • Spark Plug Change
  • Masking tape + pen
  • 19mm Spark plug tool
Overview of an m40
Do the coolant first…
        • Disconnect Battery****
Oil change is easy...
Spark plugs...
