C101
Revision as of 20:07, 27 January 2012 by Grrrmachine (talk | contribs)
The C101 plug is the biggest connector on the vehicle Loom. It allows the entire engine wiring to be disconnected from the rest of the vehicle, so that the engine can be removed easily. It is located on the bulkhead in the engine bay, next to the brake servo.
There were two versions of the C101 plug fitted. The "round" style fitted to Motronic vehicles, and the "square" style fitted to Jetronic vehicles.
Motronic
Pin Colour Function To Image
2 Green/Yellow Static oil level Pin 16 check panel
3
4 Brown Temp gauge pin 26 blue plug inst cluster
5 Brown/Green Oil Pressure light pin 18 blue plug inst cluster
6 Green/White Oxygen sensor relay Fuse 9
7 Green Switched power Ignition switch
8 White/Black Fuel rate input pin 11 blue plug inst cluster
9 Black Engine speed input pin 7 blue plug inst cluster
10 Blue Dynamic Oil level pin 20 Check Panel
11 White/Green Reset service lights pin 22 blue plug inst cluster
12 Grey Check Engine indicator Check Light
13 Green/Purple fuel pump relay fuse 11
14 Black/White Speed signal out pin 10 white plug inst cluster
15 Black/Green Unloader relay pin 1 blue plug inst cluster
16 White/Black Diagnostic connector Diagnostic plug pin 6
17
18 Black/Yellow Start Ignition switch
19
20 Red/Yellow ABS power ABS control module
WARNING: There is one difference in the C101 design between the E30s, and that is Pin 20. On early vehicles, Pin 20 is a brown earth wire, while for some later vehicles Pin 20 is a live, unfused red/yellow wire for the ABS system. If you are changing your engine, CHECK PIN 20 ON BOTH SIDES OF THE C101 PLUG before connecting the battery.
Jetronic
3
5
7 Green/Purple fuel pump relay fuse 11
8 White/Black Start Ignition Switch
9
10 Live power from ignition unfused
11
12
13
14
16 Brown/Green Oil Pressure light pin 18 blue plug inst cluster
17 White/Green Reset service lights pin 22 blue plug inst cluster
18
19
