Heating
Revision as of 10:50, 14 March 2012 by Grrrmachine (talk | contribs)
The UK doesn't exactly experience Arctic conditions, with the harshest winters being described as "a bit chilly". But numb fingers does detract from the pleasures of driving an E30, which is why your car is fitting with a Heating system.
The heating system is directly integrated into both the Cooling system and the Aircon system, if fitted.
The heating system provides warmth for the cabin based on engine temperature. By taking a direct feed from the engine coolant, a secondary radiator known as the heater matrix is warmed to very high temperatures. A fan then blows air over the radiator, creating a hot draught which is channelled into a number of vents around the cabin.
The driver directly operates the heating system through the controls in the centre of the dashboard.
Controls
Heater Matrix
Heater Blower
In order to move the air around the cabin you need a form of fan, which in the E30 is called the Heater Blower. Rather than a bladed fan like an aeroplane's propellor, the heater blower looks like an old paddle steamer with two bladed wheels. These are driven by a centrally-mounted motor
As a unit, it's accessible from the engine bay, where it sits just behind the bulkhead covered by a panel in the scuttle. There is no need to dismantle the interior of the car to access it.
A variety of blowers were fitted during the lifetime of the E30. Facelift motors (1987 onwards) are different from pre-facelift, and aircon motors are different from facelift. However, facelift aircon fans are very similar to the pre facelift version, and are possibly identical. This is very important when sourcing a replacement, since there is no chance of fitting a pre facelift motor and fan to a non aircon facelift heater box.
Vents
Erratic Blower
Sometimes it only blows on full speed, sometimes it never works, other times everything seems fine. This odd behaviour of the blower motor is unsurprising after 20 years of no lubrication on plain bush bearings, but hopefully it's nothing a bit of TLC won't fix.
The motor does need to be taken out of the car though. Once on the floor, it can be freed up with WD40, powered up in your hand, then lubricated with a light oil - repeated again and again, until it runs completely free. Then re-install it. If this doesn't get it working, you'll have to source a replacement.
Blowing Only On Max
The fan itself can be a finicky little unit, and will either not work at all or, more commonly, only work on the MAX setting. If that's what's happening, learn more about heater fan problems.
Troubleshooting
If you're having more complex issues with your heating system, such as total failure, learn more about troubleshooting the heating system
