Lollipop Bushes
Revision as of 08:35, 28 February 2010 by Richy187 (talk | contribs)
These are the bushes I chose...
First you will need to jack the front of the car up and place on axle stands, then remove the wheel on the side you are working on.
Then remove the ball joint that attaches the wishbone to the back of the hub, its best to use a ball joint splitter for this, I used the scissor type and found it relatively easy, but how you do it is up to you.
The wishbone should now be free to rotate
