Fitting Tech2 front and rear bumpers
Revision as of 06:20, 2 October 2008 by MrLEE30 (talk | contribs)
Fitting Tech 2 front and rear bumpers to facelift cars Written by mrlee
Seems to be a lot of confusion about fitting the Mtech 2 bumpers and valances to a standard facelift car. It is actually relatively easy to do and requires only some minor drilling and purchasing of clips. All face lift cars can accept the Tech 2 front and rear bumpers including 4 door, touring, coupe and cabriolets. Pre facelift cars require fairly extensive modifications to the metal valance, tow eye, front and rear bumper mounts, rear bumper/wheel arch mating location etc. There are separate sites describing this job, a PM to mrLEE30 and I will send the link. I am not a fan of the Mtech side skirts so I did not fit them, however thanks to Corkie here is a site to show you how they go on http://rapidshare.com/files/147753716/M-Technik_II_Seitenwand-__Tuer-_und_Schwellerverkleidung.pdf.html click free user wait 45sec then download, keep scroling down after the diagrams and you will find english. The tech 2 sill/door covers are specific to: a. the coupe b. the 4 door/touring and c. the cabriolets. This article does not cover any of this, only bumpers/valances. My advice is to read the whole article first before you start, as for the drilling there is a template available for this (51712239841), I didn’t have one so I explain how I did it.
Tools and parts
Mtech 2 front bumper, front Mtech valance, rear Mtech bumper. Try if possible to ensure the tow eye/fitting hardware covers are with it (2 on the rear, 2 on the front) and the front left and right brake air ducts are included as they are tech 2 specific items too, and if you don’t already have front fog lights you will need these to finish the look off.
parts: A: upper clips for lower valance : 51712239711 (7 Nos) B: expanding rivet for lower valance : 17111712963 (8 Nos) C: side clips for lower valance : 51711033719 (2 Nos) , 51711922599 (2 Nos) , 16131176747 (2Nos) D : rear guide left & right 51122239847 (1 Nos) , 51122238848 (1 Nos) , grommet 51711939303 (2 Nos) , rivet 51711936929 (2 Nos) (for better guide see: http://www.realoem.com/bmw/showparts.do?model=1111&mospid=47263&btnr=51_0660&hg=51&fg=15)
Screwdrivers, 8mm,10mm, 13mm socket set/spanners, T-55 Torx socket (cheers Smithy) and ratchet drive (1/2 inch or bigger), A ruler/tape measure, a punch and hammer, Drill and 4mm metal bit , 8mm metal drill bit, WD40 or similar, red oxide paint, paint for priming (grey), Black silicone. A mate. Axel stands or an inspection pit. The rear bumper
The Front Bumper and Valance
The side clips…on my tech2 valance the brackets that hold these clips were broken so I could not fit them without a load of messing about, I used black silicone applied from the inside to hold this part to the metal valance. If your brackets are ok then I would recommend fitting these, the technique is the same, mock up the lower valance with the clip and fixing bolt in place, measure where the holes are required for each side, drill, paint and check its right, do not fix it at this point.
Now fit the front bumper, clean and oil the side mountings, use a mate and fit the bumper as a trial first keeping it straight. Check for alignment. The front bumper has 4 adjustable mounting points, the two side mounting can be moved up, down, left and right, to get to the fixing bolts/screws you must get up underneath the front wing, it may be necessary to remove the horn on one side to get access. Adjust these as required and retighten. The front two centre bumper mounts can also be adjusted. They are held on with two 13mm bolts, which can be loosened from the front and the mounts can be adjusted as required. My suggestion would be to leave these and try to adjust from the side mountings first, if that fails then try the centre mounts. Once happy refit the bumper, plug in the indicator supply and refit the Torx bolts and tighten.
That it, job done!!
