Limited Slip Differential
the links are available in earlier editions of this ...
Limited Slip Differential From E30 Zone Wiki Revision as of 17:14, 26 July 2009 by 91.149.179.60 (Talk) (diff) ←Older revision | Current revision (diff) | Newer revision→ (diff) Jump to: navigation, search
Acai Berry is the best supplement available in the market. Acai Berry has been a revolution and is preferred by most of the people. There are various benefits of [1] but they are questioned at times. Acai Berry is quite helpful for the weight losers and this fruit also provides you with enormous amount of energy.
Generally Limited Slip Differentials are referred to as a Slipper or as an LSD. This contrasts to the normal differential fitted that is known as an Open Diff.
E30s with LSD as standard
* 325i Sport * M3
Case sizes
E30 LSD Ratios
* 3.15 - M3 * 3.64 - prefacelft 325i * 3.73 - facelift 325i * 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport * 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case. * 4.27 - * 4.44 -
What these numbers mean
What oil to use for your LSD
External Links
* Wikipedia's Limited Slip Differential Entry * How Stuff Works - Differentials * Video of open and LSD rotation
