Engines Troubleshoot
Revision as of 07:18, 16 February 2012 by Grrrmachine (talk | contribs)
Troubleshoot
| START | ||||||||
↓ | ← | Does the ICV buzz
with ignition on? |
run when cranking? |
| Starter Motor | Test CPS | ← | ← | ← | Check for spark | ← | ↓ | |
| Check for air leaks | ← | ← |
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
There's a green wire, the sneaky fuck
