Revision as of 21:58, 9 December 2011 by Grrrmachine (talk | contribs)
Clutch Disc
The clutch disc
The output shaft of the gearbox is splined, and the clutch disc fits over these splines.
Pressure Plate
Release Bearing
Master Cylinder
Slave Cylinder
