Brake Pedal
Brake Servo
Master Cylinder
Brake Fluid
Brake Lines
Brake Hoses
Calipers
Discs
Pads
Drums
Cylinders
Shoes
Handbrake
Basic checks
What can be improved?
Brake "power"
Unsprung mass,
Rotational mass
Fade (pad) resistance
Fade (fluid) resistance
Heat reduction
Disc "warping" resistance
5-Lug Conversion
Pads
Lines
Discs
Bolt-on options
- The WMS 280mm (fits 15" BBS & 16" Alpina) and 298.5mm (fits 16" Hartge & AC Schnitzer) 4-pot kits which have custom 1.25" E30-specific pistons.[1]
- 302mm disks with 4 pot callipers can be made to fit under 16" wheels - Baddave's current set-up which apparently works rather well.
Master Cylinders
BMW
Cars with 4pot callipers
- Aston Martin(various)-DB7
- Alfa Romeo GTV/166
- Audi Possibly RS2,S8,RS8
- BMW E38 730i, 735i
- BMW E31 840i,850i,850csi
- Ferrari (all newer models)
- Fiat Coupe
- Ford Focus RS
- Ford Sierra RS Cosworth 3dr
- Jaguar S type R
- Lancia Delta(integrale)
- Lancia Phedra
- Mazda RX-7
- Mitsibishi 3000GT
- Nissan 300ZX
- Nissan 350Z
- Peugeot 607(possibly)
- Peugeot 807(possibly)
- Peugeot 406 Coupe
- MG MGF
- Seat Cupra R (Ibiza,Leon)
- Subaru Impeza STI
- Toyota Hilux
- Toyota Celica GT4
- Toyota Supra
- TVR ( certain newer models)
