Instruments
Revision as of 09:48, 6 October 2011 by Grrrmachine (talk | contribs)
Above the rear view mirror of M20 models was a check panel, which warned the driver of any problems with lights and fluids.
Dash Cluster
The dash cluster is a one-piece circuit board inside a plastic shell, mounted to the dashboard. It receives its information through three plugs (white, blue and optional green) connected to the rear of the circuit board.
To control a number of the instruments, batteries are fitted to the back of the circuit board. Many problems associated with the dash cluster are caused by failing or leaking batteries which need to be replaced. Learn more about replacing SI batteries
Speedometer
Odometer
Fuel Gauge
Temp Gauge
Tachometer
Econometer
Dash Lights
Check Light
Brake Lights
Indicators
Inspection Lights
OBC
Main article: 13-button OBC
Check Panel
