Limited Slip Differential
Revision as of 18:30, 25 November 2010 by Daved (talk | contribs)
the links are available in earlier editions of this ...
Limited Slip Differential From E30 Zone Wiki Revision as of 17:14, 26 July 2009 by 91.149.179.60 (Talk) (diff) ←Older revision | Current revision (diff) | Newer revision→ (diff) Jump to: navigation, search
Generally Limited Slip Differentials are referred to as a Slipper or as an LSD. This contrasts to the normal differential fitted that is known as an Open Dif.
E30s with LSD as standard
   * 325i Sport
   * M3
Case sizes
E30 LSD Ratios
   * 3.15 - M3
   * 3.64 - prefacelft 325i
   * 3.73 - facelift 325i
   * 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport
   * 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case.
   * 4.27 -
   * 4.44 -
What these numbers mean
What oil to use for your LSD
External Links
   * Wikipedia's Limited Slip Differential Entry
   * How Stuff Works - Differentials
   * Video of open and LSD rotation
