Basic M40 Servicing
Revision as of 00:18, 6 March 2009 by Hoshy (talk | contribs) (Reverted edits by 203.184.28.37 (Talk); changed back to last version by Cloud)
M40 Engine - Basic Servicing
Scared of the Spanner?!
This guide was made for you!
  • Coolant Change
  • Oil Change
  • Spark Plug Change
  • Masking tape + pen
  • 19mm Spark plug tool
Overview of an m40
Do the coolant first…
        • Disconnect Battery****
Oil change is easy...
Spark plugs...
