Fitting an E30 Differential
Revision as of 02:42, 23 December 2008 by Gcs325i (talk | contribs)
Before beginning the job so DO NOT attempt this unless you are sure that a: you have the correct decent quality tools for the job, b: you are competent enough to undergo the task and c: you are physically up to the task, if working alone (diff weighs 35-40kg).
Preparation
The tools used were: 1/2 inch drive ratchet and deep 30mm socket, short single hex 19mm socket, crack bar, 1/2 in drive 8mm allen bit socket, 3 large extension bars, 2 19mm combi spanners, 2 17mm combi spanners, large flat headed screwdriver, trolley jack and axle stands. Its always a good idea to use the best tools you can get your hands on and the job will go a whole lot easier and more importantly safer.
Diff removal
Next I removed the 17mm nuts holding the prop shaft to the drive flange (or whatever you know it as). This can be done easily with two 17mm spanners. Put one of the spanners onto one of the nuts and turn shaft until the spanner jams against the carrier then you are able to loosen the nut next to it using the other spanner, repeat this all the way round. The last one might be a bit tricky but it is do-able in the same manner. Its now a good time to position your trolley jack under the diff making sure its sensibly positioned, remember this is a heavy unit and when the bolts are all removed the jack alone wont hold it for long if it is not positioned correctly. A flat block of wood would aid well on the jack. Raise the jack untill its just shy of the underside of the diff. Next loosen the four bolts holding the diff casing to the carrier. Just loosen each bolt one turn at this point. Loosen and remove the nut and bolt that goes through the centre of the large bush at the rear of the diff. Make sure again that you have the jack sitting ok and remove the lower two of the four bolts holding the diff to the carrier. Check jack again making sure the valve is tightly closed and the jack is touching the underside of the diff. Remove the remaining two bolts from the top of the carrier. Now after these bolts are removed playtime is over and its sweat time so make sure you are in a suitable position to be able to aid the jack in the lowering of the diff, again this has the potential to go badly so choosing a good position is paramount here, make sure you have the jack in a good central position and make sure you have yourself close enough to be of any use but not in a position where you will be in the flightpath of a possible diving diff. Once you have the five bolts removed its just the jack and the four prop studs going through the drive flange that's holding the bad boy so with great care lower the jack about an inch or until the flanges start to separate. Things will be very shaky here and the diff will have a strong urge to fall to earth so composure is key. When lowering the diff the drive flange will want to jam on the two lower prop studs so a large flat headed screwdriver will come in handy here for carefully prising them apart. When you have freed them you'll find out how ready you are for catching the diff if you have positioned the jack correctly which at this final stage should be more slightly more to the front end than centre and you have a good hold of the back end of the diff, gently lower the jack.
Refitting
